Hi All,
Does anyone know if it is possible to lock a camera viewport as I have often panned without noticing. Very frustrating…!!
Thanks,
Trev
Hi All,
Thanks,
Trev
yep, you can lock all transforms under hierarchy panel->link info
Doesn’t seem to make any difference…
you have to check the checkboxes for position on both the camera and the target…works for me
If you check all locks, then the cam wont roll either, not even with the roll tool.
Edit : there´s some object locking script on scriptspot that check all the 9 transform locks on a selected object.
Thorsten
Thanks Thorsten,
Forgot about the target… ![]()
Trev
http://scriptspot.com/start.asp?p=download&ID=2833
http://scriptspot.com/start.asp?p=download&ID=2832
Here are two scriopts. one locks, one unlocks…so you can easily add them to a shortcut or toolbar. should be easy to tweak it to work on cameras only and to include the camera if target only selected and include the target when camera only is selected.
Regards,
Thorsten
