looking for high quality wood textures
Does anyone know where I can get/purchase high quality veneer textures for:
olive
cherry
mahogany
oak
does not matter if they are not free, most important is that they are of high quality and have a few variants. Thanks for your help
http://www.veneerselector.com have loads of wood textures - depends how high res you mean when you say high res though…
They are not tileable yet, but here are the biggest woodscans i found so far (most are about 3.200x2000)…and the best thing is they are absolutely free :stuck_out_tongue:
http://www.defcon-x.de/wordpress/textures/
Hope it helps.
Regards,
Thorsten
:!: :shock: :smile:
@instinct - ok you win! :shock: :lol:
veneerselector I knew about. the other link is fantastic, thanks instinct :wink:
BUT:
still looking for larger pieces. Although the textures are high res, the actual real size is not so big, same as with veneerselector. I can of course do some paintwork on them to enlarge, but I prefer real large photographed samples to cut away rather than to tile.
btw, does anyone know if it is possible to make a shader that changes color depending on viewing angle+orientation. Many veneers have this property.
To make more clear what I mean: if you keep a sample under the same viewing angle and rotate it 180 degrees, the light and darker tones should switch.
I have these and they are very large samples (2 meters high)
http://www.highdimensiontexture.com/home.html
Regarding the colourchange. Simply use a falloff material. to change them according tho the angle between camera-vector and surface normal.
Regards,
Thorsten
thanks, I forgot about these, I once downloaded the sample and that realy looked good. I build floor texture from it :slight_smile:
Unfortunately they don’t have the type of woods I am looking after.
@instinct: what you mean doen’t work, because the dark-light pattern should switch for example when you change your view from 45 degrees to -45 degrees. With a falloff, you cannot make a difference between these two.
