looks like flickering
I rendered out a small 13 sec animation over the weekend…I had to dumb down some settings in order to get the frame time under 10 min. The animations looks good, but every once in a while it looks like shadows jump around and a wall will turn a different color now and then. I calced the IR map every frame cause I had already started the sequence. Any ideas are helpful.
Thanx all
Any chance all the bad frames came from the same node?
I’d try rerendering the bad frames
THey were all from my computer…So that could be it. I will try and re render a couple. I looked at it more closely and it looks like some of the siding every once in a while changes hue. But it is only in the back of the rendering. Everything up close looks ok…Thanx
may be coplanar faces
“I had to dumb down some settings in order to get the frame time under 10 min.”
could that b the problem?
Yeah…I am pretty sure that is it…LOL…I just needed confirmation. :slight_smile: I am still on the rc3 and I really want to upgrade after this project is complete, plus I need to upgrade the “farm” soon. But like I said in another post… Since I upgraded this computer to the Dual Quads…Nothing else in the office can handle what I throw at it.
