lwf
Well , so now after a looooong time not using LWF, i had some time and remembered, there was a tutorial somewhere…
about LWF.. but i couldnt find it..
does anyone of you remember the link ?
and by the way… what´s the advantage of this..
Tom
don’t know about with tutorial you’re talking about.
But to comp passes, LWF is the only way.
There have been quite a few discussions on LWF as I’m sure you’re aware Tom but the original post was by Throb:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=29639&highlight=throb+lwf
but his tutorial appears to have disappeared, still a lot of info in the thread.
Also, Vlado wrote one which is a bit easier to follow:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=33917
Are either of these the one you want?
Dan
Lwf
I have a fairly simple one on my site.
www.whitebirchstudios.com it is on my 3dblog page.
oh no tom… not again. :slight_smile:
Ah well.. jonas… i have some sparetime to fill right now…
time to play
thanks
ill have a look into them
Tom
There is a nice one on the Aversis site.
as far as I know you can still find throbs LWF explanation at high end 3d
This is a really good one
http://www.gijsdezwart.nl/tutorials.php and as mentioned the one on
aversis.be is really good
also check the LWF for dummies thread in the general forum
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=42988 where I posted a tool that helps with the workflow
Good luck
time to play? sounds nice :slight_smile:
ah finaly 1000!! YEAH :slight_smile:
