The soffit is in the shadow, I want to show the light fixtures on the soffit; but they won’t turn bright unless I do night view rendering; also, I want to show indoor ceiling lights seen through window bright as well. Below is the light setting.
Hey @lynn2000
Thank you for your message.
A: You are using an emissive material with a low luminance setting (Lamp Shade Exterior). With a higher Luminance selected (Frosted Bulb for example has a Luminance value of 210 000 compared to your 1 300) you should be able to see the emissive material during day.
B: However, we don’t recommend to illuminate your scene only using emissive materials. Please instead also add artificial light sources to your light fixtures in Revit, these provide a better lighting quality. I hope this helps!
