Making quick grass
Can Corona make a quick grass effect using Corona hair, if so is there any tutorial available?
Thanks.
Hi there, Here’s a quick set up for you. Depending on how close you want to be to the grass, some good results can be made. :wink:
Grass_hair.c4d (1.87 MB)
Thanks for the scene however I’m using c4d broadcast version and It’s the file opens with missing hair plugins.
Is there any work around?
Nope, hair is part of the studio version of c4d.
make a patch or patches of grass then use mograph to distribute
^yep, this would be the best next thing, or perhaps a plug-in of sorts.
ie: Grass Kit V2 for CInema 4D and Vray | CGTrader
It looks amazing. Can you share the file? I’d like to see the settings. I tried few times and it never look so good.
Thanks for the file Beanz!
The file is listed, look harder :wink:
No probs :wink:
Found it. Thanks :smiley:
