Hi
Due to a specific circumstance I found myself using the standard max file output today after a long time.
I noticed that it remembers the gamma value override setting in the output dialog. Can we have that for the VRay output, too?
I use the override every time since I had multiple occasions where max f***** up the gamma (due to old scenes etc…) and the render was basically garbage.
My Pre-Render Check script now also sets the gamma at render time, so no matter what weird and wonderful setting it is set to, when you render it WILL be 2.2. The script also does some other useful checks before render.
I still have to upload the updated script, but until then you can just stick this into a text file and save it with .ms extension and stick that into a pre-render script
fileingamma=2.2
fileoutgamma=2.2
Actually not a too bad idea - still, having it behave the same way like the max output would be preferable.
