I’m trying to create a mask from trees/grass produced with corona scatter. I tried to select a coronascatter object with CMasking render element, but it just renders black. I can’t think of another way to do it, do you have any ideas?
Go to your object properties of your scatter instances and change the object ID on your G-Buffer to 1
then in your Cmasking render element tick object Gbuf ID and change to 1. If you want to separate the elements from each other use RGB Mode and assign a unique ID to each.
Currently this is a limitation - you either need to use another method as suggested, or you need to select the scattered (source) objects, not the CScatter object itself.
