Matching/tracking camera movement - import camera path from other sources
It would be extremely useful to enable import of camera/camera path produced in software such as 3ds max, after effects, boujou etc. in order to create Enscape videos suitable for perfect overlapping with real videos from the site (drone/ aerial videos).
Workaround for this process would be enabling import of recorded video as a background in the Enscape video editor. This way we could use real video as a guide for creating Enscape camers and path for manual camera movement matching…
Hey @some1new , thanks a lot for your request.
I’ll can file this subject as a dedicated feature request, but this is something which is not easy to implement at all since every mentioned software solution works in a different way, so it would make more sense to file the workaround you’ve proposed instead if that is also okay with you. :slight_smile:
Furthermore, we’ll generally add some major improvements to our video path in the near future, so definitely stay tuned for that and thanks a lot in advance for any further response. :wink:
