material bug or what?
I found a problem in material setup and I think wasnt be there in some previous releases of VRay. Here it is:
VRay Material with some reflection color and fresnel. Put for example noise map in reflection slot. Its ok and when you try to change color of reflection, it didnt do anything. Its ok, we have a map in reflection slot with 100% influence, so its right. But now:
VRay Material with reflection color and fresnel. Now put mask map or VRayCompTex in reflection slot. (and for example bitmap, noise map or something to mask/vraycomptex slots). And change color of reflection of vray material. How is it possible that reflection is changing when we have map with full influence in reflection slot?
And I think it didnt use final texture of mask/vraycomptex maps.
Can you upload a scene because it’s fine in my tests ?
Sending…
Look at Slate material editor. Mask map is attached to reflect slot. But when changing reflect color, preview in VRayMtl is changing. When attach only noise map, its ok.
material bug.zip (22.9 KB)
Ah I see now , I was testing with comptex. Actually there is nothing wrong.
Quote from max help:
"By default, lighter (whiter) areas of the mask show the applied map, while darker (blacker) areas of the mask show the underlying material color. "
:slight_smile:
But with comptex is the same.
So black area means transparent? So how I use my own bitmap with some other map? When I have to use bitmap with some other map, but black means transparent. I need black as 0.
How can be transparent final map from comptex?
V-Ray Comptex map works fine in my test, so no transparent parts of the map are produced. The reflection color is not taken into account when this maps is set.
About the Mask map, i can advice you to use the Composit map instead, because is more adjustable and you will be able to set “Black” padding color, for an example.
Yes, composite map can do this job.
But when I try composite map and put it to reflection slot, reflection color still change the reflection in material preview. I try it one more time.
According to my tests - reflection slot color doesn’t affect neither the render nor the material preview slot when VrayCompTex is used.
Please send us example scene if the issue still persist.
Also it is very interesting for me why do you change reflection color slot when you want to be black ? I meant you can use Mask Texture and it will work correctly if you have Black color in the textures slot - what is the reason to change this color ?
material bug01.zip (31.8 KB)
It happend only when comptex is set as subtract or difference I think. So maybe its transparency thing again?
Sending scene.
comptex.zip (23.6 KB)
We reproduced the issue, now it is in our bug-tracking system.
Thnak you for your feedback.
Thanks for looking into it.
