I have the problem for Material Editor Slots. It’s doesn’t show picture. How should i do?
Make sure that renderer for material editor is set to Corona: Render Settings>Common>Assign Renderer>Material Editor
Thank you for the answer.
I am sure about Render Setup is “CoronaRenderer”
But now i can do it!!!
If anyone has some this problem. Can should do the same this picture.
It work ^^
I have the same problem. As you can see the sample slots are black and the basic parameters are still those of VrayMaterials.
Your Corona Renderer not activated
Run render process and choose your type of license
Ok, thanks for the suggestion. But the demo does not activate automatically; so, where to copy the activation code back? I can’t find a place to paste the activation code (It’s embarassing, I know…)
maru
February 27, 2015, 3:40pm
8
Black sample slots solution:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000568654
ST:
Missing ui elements solution:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000568656
I hope this works. Please contact us at support system if there are still any troubles.
