Material grabs other's object color
Hello, everyone!
I turned off all reflections on both grass and stone materials, but stones keep grabbing sticky green color. How to prevent them doing this?
Need your help guys.
It’s the global illumination. If you want to lessen its effect, you can use rayswitch material. https://coronarenderer.freshdesk.com/support/solutions/articles/5000529341-what-is-rayswitch-material-and-map-
Saved my week!
I did it globally “render setup>performance>global illumination>primary solver” as you told another guy in 2015
[https://forum.corona-renderer.com/ How to render reflections in biased mode (no GI) ](https://forum.corona-renderer.com/ How to render reflections in biased mode (no GI) )
Thank you!
But without global illumination… why use Corona?
You’re right. Probably I need to consider excluding GI by using Corona Rayswitch Material and keep global GI on.
