Material node editor Freezes
I had problems with the Material node editor often freezing when using it, and I had to force quit C4D. Then I tried disabling “Device Selection” which is “C++/CPU on Intel…” since GPU rendering is not supported on my Mac Pro 2019 with AMD Vega II. And it’s not freezing anymore :sunglasses:
How come this has an effect on the node editor?
And is there a way to set this to be disabled as default?
(Now I have to remember to uncheck it every time I start C4D, and sometimes I forget and it freezes/crashes)
Thanks!!
Cinema 4D R23, MacOS Monterey
Nobody knows anyting about this?
@viktor_angelov I tag you here since nobody seem to know anything about this. I think this should be mentioned in the manual or FAQ, since it would have saved me so much trouble. I pay for 3 V-Ray licenses and often waste my time on stuff like this, instead of creating.
HI @torebernhoft Thank you for tagging me. Could you please try to uncheck the Enable Node Previews from the Preference menu and see if the Freeze will appear again?
Please, find the screenshot useful:
not sure if it’s a parallel or not, but in Maya I get a lot of hypershade crashes (material node editor) when I also have the Arnold plugin loaded. I remove that and don’t get crashes. turning off previews in Maya also helps some issues.
Thanks Viktor! I tried now with node previews disabled (unchecked), and it seems much more stable. I will try this setting for a few days and report back how it holds up.
I was hesitant to use this as I want to see the node previews, but I set the output node to show previews so it shows in the viewport at least. That works great, but still I will miss the node previews…
But for stability I can make a sacrifice :wink:
Hey, thanks for the insights. I removed redshift and that has also helped me.
Hi @torebernhoft
In general device selection should not have any effect on material previews. Can you give some more information about the types of materials this is occurring with? Also do you have any idea if the viewport previews or the thumbnails are the problem? You can test that by quickly playing around with a material that isn’t attached to an object in the scene.
Great to know that @torebernhoft I happy it feels more stable. However, please make sure to test what my colleague @bozhidar_ivanov is recommending. We would like to insure that you can work without wondering if the software will freeze.
Hi there @bozhidar_ivanov . I have tested today with the viewport previews, and with node previews OFF but viewport previews ON (via the last output node). It does not freeze, and works fine. I can also now isolate (solo) the nodes and they will show in the viewport + the interactive VFB without any problems. And these are materials using high-res textures, and it works fast and stable :slight_smile: So I guess it all boils down to the disabling of the node previews. I will report back in a few days and see if the problems is really solved after some more use.
Thank you for sharing @torebernhoft We are looking forward to hearing from you in couple of days to insure everything works as expected.
