I don’t know why, but after some time of use the material preview and the texture preview doesn’t work. I need to restart Rhino. Is it a known issue or should I try to find a way to repeat it? But rendering to the frame buffer works.
-Micha
-Micha
Dear Micha, hello.
Thank you for pointing this out.
In the latest released version (5.20.02) a more detailed way to monitor the preview is implemented.
So, next time when it happens, please go to the new V-Ray Log Window and choose Filter Source Assets Preview Renderer and send us the information right away.
There the issue should appear.
It will be also written in the vray-neui.log (easily found from the About windows as you know). You could add it too.
Let’s get this solved.
TS
Today I lost the preview by this error:
[TABLE="cellpadding: 0, cellspacing: 0"]
[TR]
[TD]15.12.2021 17:43:41[/TD]
[TD]Warning[/TD]
[TD][V-Ray Asset Editor] Error: 12 UNIMPLEMENTED: RPC method not implemented /assets.preview_renderer.AssetPreviewRender/CreateRenderer at Object.exports.createStatusError (C:\Program Files\Chaos Group 5\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\common.js:91:15) at Object.onReceiveStatus (C:\Program Files\Chaos Group 5\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client_interceptors.js:1204:28) at InterceptingListener._callNext (C:\Program Files\Chaos Group 5\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client_interceptors.js:568:42) at InterceptingListener.onReceiveStatus (C:\Program Files\Chaos Group 5\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client_interceptors.js:618:8) at callback (C:\Program Files\Chaos Group 5\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client_interceptors.js:845:24) { code: 12, metadata: Metadata { _internal_repr: {}, flags: 0 }, details: 'RPC method not implemented ' + '/assets.preview_renderer.AssetPreviewRender/CreateRenderer' }[/TD]
[/TR]
[TR]
[TD]15.12.2021 17:43:56[/TD]
[TD]Warning[/TD]
[/TR]
[TR]
[TD]15.12.2021 17:44:04[/TD]
[TD]Warning[/TD]
[/TR]
[/TABLE]
Hello, @Micha .
If today the preview is still missing, would it be possible to connect via TeamViewer and perform some debug steps?
I will send you now a PM.
Today I got the problem again. It’s a Rhino task which was open for a longer time - the error message date is from yesterday. If I remember me right an other Rhino task was crashed yesterday, so maybe it’s not really a bug more a side effect. I found a solution - starting a second Rhino task will renew the license connection and the preview of the first task works again.
Exact the same errors I had 2 times, yesterday. It happened when I change asset preview device from CPU to GPU.
Quick solution was to change default render engine in rhino settings back and forth to Vray.
18. 1. 2022 14:45:14 Error [V-Ray Asset Editor] Error: 14 UNAVAILABLE: TCP Read failed
at Object.exports.createStatusError (C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\common.js:91:15)
at ClientReadableStream._emitStatusIfDone (C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client.js:233:26)
at ClientReadableStream._receiveStatus (C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client.js:211:8)
at Object.onReceiveStatus (C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client_interceptors.js:1272:15)
at InterceptingListener._callNext (C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client_interceptors.js:568:42)
at InterceptingListener.onReceiveStatus (C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client_interceptors.js:618:8)
at C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayneui\resources\app.asar\node_module s\grpc\src\client_interceptors.js:1029:24 {
code: 14,
details: 'TCP Read failed'
Dear all, hello.
Thank you for enriching this topic with facts.
The Asset preview behaviour will be improved soon.
The work is in progress and we will contact you to test it and confirm.
@pavol_pastork , please define are you experiencing it randomly.
We have detected why it is happening.
In most cases after restarting Rhino or the PC the preview should appear.
TS
Since the latest update I don’t get the permanent error messages anymore but the material preview stops to work often.
Hi Micha,
This is not good.
I was hoping that all preview issues would be gone at this point.
Can you describe in more details what is happening?
Konstantin
Hello @Micha ,
Sorry to hear that. Could you provide more detailed info and a vrayneui log from a session in which the problem appeared?
Nikolay
Hello, @Micha ,
As Konstantin mentioned, we were under the impression there are no more outstanding asset preview issues.
If you are willing to spare some time to help us narrow down the cause of the issue, please provide the following info:
Both I and my colleagues are ready to assist you with gathering the requested info or troubleshooting the issue via remote connection if you feel comfortable with this approach.
Kind regards,
Peter
After some tests I have some more infos:
* I lost the preview and started a second Rhino task - there the preview works, but still not at the first task
* I started a stand-by state of the PC and rewoke the machine - the preview of the second task is still working
* I set the Rhino tasks in the background and let Chrome in the foreground → stand-by → rewoke → the preview is gone at the second Rhino task too
So, the issue is not dependent from a specific opened Rhino scene. It’s not a license issue since the preview works at a new Rhino task. The issue is related to the PC stand-by mode and that Rhino is in the background.
I sent the log files per support ticket #29856.
Good luck,
Micha
Perfect. Thank you for the confirmation!
We were able to preproduce the same behavior on our side.
Our dev team is now scheduled to work on its solution.
Regards,
Peter
Great, I’m glad you got the bug. ![]()
