parametric pony primitive ![]()
I found some models on makerbot`s site. Simply open and resave in .max file. You can use this for primitive ![]()
http://www.thingiverse.com/thing:25282/#files
Mane_6_models_MLPFIM_-_Fixed.zip (1.3 MB)
It’s looks realy cool for tests…opacity, sss, dirt, shadows etc will be better on this model
neat!
Hi! It’s great, I found how to load custom scene, but it is in Compact material editor mode! How can I rotate and change object in Slate mode?
thank You!
That’s super useful Keymaster! Actually been using only sphere preview all these years.
How does this prove custom objects are useful? ![]()
I don’t know about you but I usually create materials in separate scene with a studio lighting setup and for this I tend to use some more complicated object than a sphere to better understand how the light will reflect and refract.
With custom preview I can use the same object for previewing and hopefully need to click render fewer times. ![]()
A question vaguely related to this thread: Is it possible to adjust the preview scale like you can with the default preview from Compact Material Editor → Options → Render Sample Size ?
Doesn’t seem to be working with custom MTL preview.
Maybe a BUG?
() Double click on the material slot. A new sphere preview is opened.
() Try to rotate the preview outside the Material editor → VEEEERY slow…
For me it’s not moving… ![]()
The problem maybe with the A5…But I can’t wait the A6…
Only available in the daily
That’s great man! When is version 6 coming out?
Only Keymaster can reply )
or ‘not even KM can…’ ?
When all he wants to achieve for a6 is achieved let’s say ![]()
It works here as expected. Seems like 3dsmax is deliberately not updating the pop-out view as often, but the one in mtl editor is updated in realtime. Mental ray behaves the same way.
Ah, ok. so it’s a 3ds max “bug”. Good to know.
Hi all,
You may be aware of Bertrand Benoits mat test scene ball (get it here). Note: It will have to be changed over to Corona scene first.
I’ve went ahead and uploaded a version here for material previews. Bertrand has gave me permission to upload it here. He actually emailed straight away :] Thanks Bertrand.
I’ve been using this ball for a while but I’ve optimised it for corona from the VRay one I had. I also made it so it can support up to 8 multi-sub object materials. You can add more ID’s to the ball if you want. I’ve spilt up the ball into 8 different elements to make it easier to edit the ball if you do. It’s better in that if you have only 2 IDs for instance they don’t get scatter over smaller areas. (see screenshot)
There’s two lights in the scene which illuminate the ball. The loader does not load cameras unfortunately (only lights). I had to rotate the ball by 5deg and reset its x-from to appear at a slight angle.
I hope you guys like it.
One more thing. Does anyone know of a way to change the preview to the custom object inside the slate material editor without having to switch to basic mode to do so? Seems silly now since it’s been part of max for a while now. 2010 (I think).
EDIT: 2011 Scene File added
BBB3viz Material Editor Ball - Corona.max (1.7 MB)
BBB3viz Material Editor Ball - Corona Max 2011.max (1.61 MB)
well done !!!
