Materials not sticking
Hi All- is anyone else seeing object materials reverting between sessions? Hmm- It looks like if there is a named material on a layer (like from another renderer when the geometry was first built) the Vray material replacing it does not stick between sessions. I’ll test some more.
-Pascal
we’re looking into it, so far I haven’t noticed anything like this, but I haven’t really been switching between renderers much. I’ll let you know if I find anything. Thanks
Pascal,
I have just tried scenes orginated with Flamingo, Brazil, and Maxwell renderers. I do not come across this problem.
Can you send us a scene that you can reproduce this problem in.
Thanks.
Corey
Hi Corey- I cannot make it happen with a new file either. What I do see is that a material assigned in Flamingo leaves its name and material color in the material column in Rhino’s layer control and neither of these changes to reflect the Vray material when that is assigned to the layer. But so far with a new file the vray material does seem to stick to the layer.
-Pascal
Pascal,
I did find something funny where the Flamingo material would not get recognized after applying a v-ray material to the same object in the scene without saving.
Strange…but we will keep our eye on it.
Corey
