Hey
I must be missing a tick somewhere or something but how to get matte shadow work with Vray? I keep seeing incorrect reflections.
Regards
Dariusz
Hi, could you go with a mtlwrapper ? i use that instead of object properties…Chaos Docs
It has the same problem. I’m sure its user error but I cant figure out what I did wrong…
What kind of reflections do you expect to get? If you expect to see the grey plane, simply turn off “matte for reflections/refractions”. Also, without looking at your scene to see what environment overrides you’ve put in it, it’s kind of hard to figure out what’s going on.
Might be related to this one maybe?
http://forums.chaosgroup.com/showthread.php?92169-3-5-Beta-2-Bug-in-Domelight-with-Ground-Projection
Yea I think thats it. I’m mostly bugged by the bad reflection in matte shadow plane and in the edge between plane and environment. Will get u scene.
