[Max 2020 + Corona 4] Physical Cam bug (Freeze)
I don’t use Physical cam anymore, but I have a problem when open old scenes that use it.
I can’t open or merge those old files. After a few hours, I figured out that the problem is Physical cam + Auto Vertical Tilt Correction + CoronaCameraMod on top.
You can re-produce by creating a Physical cam > Enable Auto Vertical Tilt Correction > Add CoronaCameraMod on top.
I don’t have any problem with max2018. So, I’m not sure if the problem is from Max or Corona side.
**Corona4 hotfix1
Cheers,
Thanks for reporting this.
I can also reproduce it in Max 2020, but not in earlier versions of Max.
I will report it to our dev team and do my best to keep you updated.
Thanks,
Rowan
(Internal ID=381093080)
It looks like this was an issue with 3ds Max 2020.
However this seems to be fixed in the latest version of Max (2020.2).
Please can you update to the latest version of Max and see if the issue is resolved.
Thanks,
Rowan
