Max 2021: Substance error message before every render
Hey guys,
I get an error message from the Substance plugins telling me that an incompatible renderer was found (V-Ray Next 4.3). Even if I tell it not so show up again, it shows up. Any way this can be fixed permanently?
Yeah incredibly annoying. I ended up uninstalling.
Update to the latest from here:
https://www.substance3d.com/ecosyste…ce-in-3ds-max/
Does that get rid of the dialog about Substance scripts when you switch renderers? I only see that dialog when I switch renderers. It is annoying, but I don’t often switch renderers once I have set one (except to use Krakatoa to save particles sometimes, which requires switching back and forth).
Yes, it stopped showing after updating.
I only use Vray, VrayGPU, Corona and Arnold, so I’m not sure about Krakatoa.
