Max 7.5 Shave and Haircut problem
Hello Vlado,
We have a scene that we are trying to render using hair (Shave and Haircut in max 7.5) for grass (in the past we used VRayFur and Displacement and it flickered) but we keep getting a vray exception. We have alot of trees in vray proxy format and in the past it render ok except for the flicker. I would send the scene but it as quite a number of xrefs i could merge all if you want but there is still the problem of the vray proxies that are quite big. Also i have done alot of test with a simple plane and hair and it render ok with all the vray options that i could remember (VRayShadows, IM, Lightcache, etc).
Daniel Santana
VRay exception
UNHANDLED EXCEPTION: Broadcasting NOTIFY_PRE_RENDERFRAME
Last marker is at P:\Vlado\SVN\vray\vray\src\vrayrenderer.cpp, line 1425: Preparing global light manager
Please send the file c:/vraylog.txt and, if possible, (a part of) your scene to vray@chaossw.com
Press Cancel to abort rendering or Ok to continue
OK Cancelar
I done some more test and realised that erasing all the speedtrees resolve the problem. But maybe another plugin that has something to do before the render start, may cause some problems for someone else.
