Max crashes if I check render to V-ray imge
Hi guys,
I’m having troubles with a scene where if I render the image using the vfb everything works fine but when I check the option Save V-ray img file, Max crashes and closes.
Does anyone have had an issue like mine?
I’m using max 2012 and v-ray 2.30.01
Thanks and best regards,
SOA
Does this issue appear for every scene or just to a particular one ?
Are you sure that you are using version 2.30.02 ? I don’t think we have such version for 3DSMax , perhaps you’ve had in mind 2.30.01
Would it be possible to install the last official 2.40.04 version and try to save V-Ray image file.
Hi Svetlozar,
yes, I confirm the version. I made a mistake typing the msg.
At the moment is not possible for me to install the 2.40 but I can send you the scene via ftp to verify it.
Thanks and looking forward to hear by you.
All the best,
SOA
