Morne
1
Hi all
I have an array of objects
inside
countBB = 0
for obj in bbObjsArr do
obj.name = "sdgfdgf" + countBB
countBB = countBB + 1
But its not working
even if I say
thisnumber = countBB as String
and then change the naming to
obj.name = “sdgfdgf” + thisnumber
it still doesnt work
Using ‘as string’ should work.
This works for me:```
local objsAR = getCurrentSelection()
for i = 1 to objsAR.count do objsAR[i].name = “NewName” + i as string
You could also use UniqueName() then you don’t have to add the numbering yourself.
Morne
4
Could you elaborate a little on that one?
How would I use it in my example code?
With your code it would be something like:
bbObjsArr = getCurrentSelection()
obj.name = uniquename “Name”
Morne
6
Both work great, but for the current situation, uniquename worked better
Thanks guys
