Maya 2025 viewport 2.0 issues
Not really a Vray issue…but good luck ever getting a straight and useful answer over on Autodesk forums…Has anyone been using recent nvidia drivers and been having viewport 2.0 issues? Currently if I make a shader my viewport 2.0 freezes. Trying out rolling back a few versions to see if it helps.
I never use updated drivers unless tested by Chaos. Just install the qualified version.
Pardon my ignorance, but where do you find the qualified version? I rarely update anything also, I now Im probably going to even less…
Also, I switched from Direct X in my crashy scene, to Open GL, and everything is fine now…weird.
https://support.chaos.com/hc/en-us/articles/19958460610577-V-Ray-GPU-minimal-and-recommended-system-requirements
Yeh, Im pretty sure I ran one of those recent drivers and it killed my Maya…having said that, I have also changed to Open GL and it seems fine now…I might do some proper testing when its not friday wine time. Thanks for pointing me to the support doc.
