Meadow Grass
Hello
I’m trying to create a meadow in a large site plan. Similar to attached images. Is there an Enscape Asset that best match the result I want? or should I use a custom asset?
I tried using the tall grass material, but it doesn’t go high enough.
+1
If you look at page 20 of this pdf there’s a render I did using Enscape assets and the Skatter SketchUp plugin https://www.tours.blockcpm.studio/wattstown-ht12/PDF-Flip/
There’s a lot of ‘weed’ type flowers in the asset lib you could Skatter to create a meadow like effect
ok nice one Paul, and what about scattering in ArchiCAD? do you use it or only with Sketchup?
Thanks, cheers!
No idea about archicad, I don’t use it, sorry
Scattering works in Archicad as well. Keep the Enscape window open and click that multi-asset icon, or whatever it was called.
