When I set my V-Ray memory to 0, and auto, is this for all the machines? I have 32Gb on my main workstation, and 12Gb on 5 slaves. When I set V-Ray to something like 19Gb, my slaves max out on RAM, and never render. Now, if I set my V-Ray memory to something like 6Gb, my main workstation does the "Uploading Geometry, which takes forever. Will V-Ray memory o, and auto, is it a percent of each machine? I hope this is clear.
if i understand correctly 0 is more like “unlimited” than “auto” but id like to be wrong…
Yes. I guess the two are night tied together.
What’s happening is, my slaves have 1/2 the RAM my main workstation has, so they are swapping to ROM. 45 minutes into this render and the slaves haven’t engaged yet. When I look at the slave’s task manager, they are at their RAM max.[quote=“Javadevil, post:83, topic:26415, username:Javadevil”]
[/quote]
Switch off displacement for the base render, and do the displaced objects as a separate pass which has been optimized to fit into 12gb.
You cant really work on a machine with 32gb and expect it to fit into 12 at the end without some very heavy optimisation.
0 is unlimited dynamic memory. You could try setting it to something like -1000 and then its the physical memory minus a gigabyte, but this is somewhat experimental.
