Metalness IOR Documentation Inconsistency
Is there a reason as to why the VRay help doc on Metal IOR is different from the one posted on the blog?
Blog Post:
VRay Help Doc
The reflection colors are not the same across the two charts.
Plus the presets uses the reflection values from the blog post.
I just want to be sure which chart to use.​​​​​​
The values from the Documentation page are the correct ones. The difference stems from the more accurate metallic fresnel, which was implemented in V-Ray 6 and does not require pure white values for the reflection.
Arh, I see.
Good to know.
Will the presets be updated to reflect this change?
The presets are already with the updated values. Tested it just in case with 6.00.08.
Splendid!
Thank you :slight_smile:
