We’re looking at object motion blur with the vrayphyscam but are only managing to get image-based-blur and not object-motion-based-blur.
Is there a way to do this within vray, or is this a limitation?
Cheers
Nik
Cheers
Nik
you mean doing motion blur that you find the setting for in the object preferences? vrays camera motion blur is turned on in the vray camera itself
i have a fast moving teapot on an arc trajectory, and i’m using the vrayphyscam with a suitably slow shutter speed.
with moblur turned on in the vrayphyscam i end up with a straight line of blur instead of a curved blur as it should be since its on an arc.
i was wondering how i get the curved blur i’m after?
You need to increase the geometry samples parameter in the motion blur section of the Render Scene dialog.
that’s the answer i was looking for.
thanks heaps vlado.
