I am in desperate need for some help/guidance modeling this object. I have a very short amount of time to make this happen. I don’t do much modeling of this type so any and all help would be greatly appreciated! I would like to try and keep this somewhat parametric because I am pretty confident that this will change multiple times.
I am attaching a couple of images for reference. The photo is fairly similar to what I need to accomplish. I also have a quick top down of the beams and their layout.
To keep a BIT of proceduralism i’d to the beams as splines with an extrude/shell combination. That way you can at least control the height and width of the beams globally.
I’d rather suggest creating a spline in top-view, attach a beam to it then delete the newly create spline. That way you can force the spline’s coordinate system in top view. If you then use an extrude and a shell you should be able to get straight ends as in the pictures. Same for the crossing plates.
Try this, a Max parametric script for $25, 2 weeks left on the promo price, you would need to be able/learn Nurbs modelling to ‘attach’ the segments too, but it works extremely well!
Thanks for the great feedback…I am looking into these options now…I will post up what I have and see if anyone has some suggestions. It is closer to the final shape that it needs to be.
Okay, I was able to somewhat figure that last shape out. Now the direction has changed completely and they would like the new structure to resemble the following structure. How in the heck do I model that? That shape is going to be similar except that the back side of the flair needs to wrap around and return back to the ground creating a tunnel area.
I would love to have some guidance working with those two programs since I have never really spent much time in either. They both look to be a little on the intimidating side. The hardest thing I am having problems with is just getting the surface done properly. I will see if I can do the lines quickly inside Max and then post it up. It would be like a shell of what should happen and then go creating the surfaces from there. Once I figure out how to model it properly, then I am assuming that Grasshopper can wrap that surface with the above structure. I am really close to just outsourcing this part because I don’t know if I am going to have enough time to learn these tools in time.
Thanks for the great suggestions and I will start working to see what I can do.
Okay, here is my attempt at making this shape. Obviously the inner core is pretty straight forward. However I am having LOTS of problems trying to get the Top surface to blend with the outer wall. Any suggestions? I am uploading the Rhino file if someone is wanting to take a look at it. I still have a ways to go, and I will be trying to take a look at grasshopper a little later on today.
I am not really concerned about super accuracy at this point because the design is in flux. I am just trying to get a diagrid structure that is consistent across the entire surface.
Thanks again for any help and insights! You guys are saving my butt big time!
When you posted the last image I thought you were concerned about the framing structure but if your only interested in the shape you could approach it simply by creating a spline and do an array of the said spline then add a free form deformation modifier to shape the thing. I did a quick example of the what I am talking about. It took me a minute or two to do this.
Adding a surface modifier would skin it.
You can follow the framing of your photo using this method.
Hey Donald, Mike Brown here. Small world… I was doing the Max modeling with the Branding agency on this project and built the original lattice. Nice to run into you over here
For what it’s worth, here’s how I modeled the lattice work in about an hour while still keeping the model flexible for Lots of design changes, as I’m sure you’re well aware… there were many
1. Built a generic vertical lattice section with Splines
2. Make renderable at whatever dimensions necessary
3. Add edit poly mod to keep lines orthagonal while bending
4. Used the bend modifier to just bend the top half or a little more as it bent down to the ground
5. Draw spline out on the ground where the lattice work is going to flow.
6. Apply Path Deform to Lattice and align to floor line. - The path deform was the real power behind this approach as I could just tweak a couple settings and/or floor spline to change the whole shape dynamically..
7. Copy, move, and tweak stretch parameters, % along path, to make each segment of the lattice.
8. Delete un-necessary spline segments to follow the contour of the curved wall in the space we were working with & apply another holistic Path Deform to the whole lattice to get it to bend towards the entry…
*Kept everything stacked on top of the spline so I could always go back and just add delete and modify splines as changes were made and have it ride back up the stack…
I looked at doing Rhino as well but just decided to stay in max due to the time constraints we were working with as that’s what I was most familiar with and find Rhino a bit intimidating too
Cheers Donald, hope to run into each other again soon.
Hey Mike! Your company does some very impressive work! I remember looking through your website when this job came back. It really is a small world! I met a ton of people out @ Siggraph last week and it was great to put some names to faces.
Yeah, I have been utilizing your methods and tweaked them quite a bit to fit with the small changes. The design is changing quite a bit and I was having a LOT of problems utilizing your methods. The severe stretching and compression of the structure is something they are really trying to get away from, so I am pretty much giving up on the path deform stuff. There are a lot more bends and twists and all kinds of other crazy stuff going on right now and it is constantly changing. The most difficult part is getting a more consistent structure size throughout the entire piece, like some of my earlier reference images. So I was heavily swayed towards trying out Rhino with Grasshopper. I will admit that this is WAY outside of my comfort zone and the learning curve seems to be almost vertical. I have spent a LOT of my personal time trying to get up to speed as quickly as possible. Most of our modeling is pretty boring stuff, so this is a nice change. Just wish I had a little more experience with these programs.
Rhino has been pretty easy to get my head around. I am struggling more with the concepts of Nurbs modeling more than anything. I tend to model myself into a corner because I am thinking Polys/Modifiers, so I seem to be starting over quite a bit, but the more I work with Rhino the more comfortable I have become. We are starting to do a lot more rapid prototyping that things too, so I figure I will have to learn Rhino at some point anyways!
Anyways, your stuff looks great! I hope you didn’t have too much of a problem dealing with my files. The back and forth was getting a little confusing.
Thanks for the kind words Troy! *just realizing your name is not Donald Oops. You guys have some great stuff going on as well. Really wish I could have made it to siggraph this year, I’d love to meet and greet too.
Totally agree on the revised modeling methods. The stretching was good to get some concepts out fast, but it was definitely getting to the point where things were going to need to get more exact. I was kinda figuring it would have to be-re-built at some point, but the work flow was working for the earlier stages
You’re files came over just fine and that was a neat trick linking the xref to the node… Our original model was out of scale a bit as we were building from raster pdf files and referring the earlier renderings… part of the process sometimes.. It’s definitely a great challenging project to work on, best of luck nailing things down.
Okay, I seem to have run into a MAJOR problem with some of these tools people have recommended. Paneling Tools & Grasshopper only really work on a single surface. Once you have multiple surfaces combined into a polysurface, I am no longer able to use the paneling tools.
Any suggestions?
I am attaching the final-ish shape that I would need to panel similar to the earlier images. I would LOVE to model this shape as one continuous surface, but with my limited knowledge of Rhino, I am failing miserably at that.
This was one tool I was going to pursue looking at to finish out this particular model. Perhaps you might find it useful…
One approach I was thinking, was make a poly surface similar to the squash and stretch path deform method… but then using this parametric array plugin to space the diamonds evenly.
