Monitor
I removed the driver that came with the monitor and it didn’t help, however, Direct 3D seems to be working. There is a fix for the small icons (3dsmax.exe.manifest), so maybe I found a viable workaround.
If it is Nitrous, and it seem to be the case, that would be a driver issue, correct? Direct 3D works, but doesn’t have the features Nitrous has.
You can size up the fonts in the Quad menu in Customize User Interface/Quads/Advanced Options, this helps me a lot using Max in 4K.
Also, my Dell monitor has a menu to enable Display Port 1.2, which was off by default. This was needed to get 60hz refresh rate instead of 30hz.
I just checked and mine is set to DisplayPort 1.2 by default. I’ll check out the quad menu settings.
I got some information from NVIDIA, which was great to see. The answer isn’t great, the quick reply from an actual person was great. When do companies get so big that they think web forums and other user comments are sufficient. I am not talking about Chaos, they have awesome support, I am talking about Autodesk. Autodesk is like Windows, so what is like Apple in our arena? You pay for high prices software, you should get awesome support. Just the other day I chatted with a live person at Apple and in the past I have scheduled support calls with them. Both Windows and Autodesk seem to be black holes.
Hello Bobby,
Thank you for contacting NVIDIA Customer Care.
This is Ayub, assisting you with the issue you have.
I understand from your email that you are experiencing issues when using Nitrous driver with AutoDesk 3DS MAX.
I apologize for the inconvenience caused but unfortunately since the program developer says that 4K is not yet supported with the program, then the hardware will also not register. For it to work, both the hardware and the software have to be compatible with 4K. The graphics card is compatible but the program isn’t, hence the issue.
Even still if you need this to be investigated, I can forward this to the concerned team and they will look into this, but I am not promising a quick resolution, only that this can be looked into and if possible, then resolved in the future with drivers or patches from the software developer itself.
Looking forward for your update,
Best regards
Ayub
I saw this in the desktop icon’s properties. It didn’t do anything, but at least they are thinking about making it compatible with high DPI screens.
I have tried everything and what I have landed on is just setting the scale to 200%. Direct 3D doesn’t have some of the display options Nitrous has and the icons are still too small. With scaling to 200%, there is no lag and the icons are big enough. I just set it back to 150%, when I exit MAX, for everything else to look good. It would be great if when I launch MAX, it changes and when I exit, it changes it back, but I am not that lazy.
This is a standard windows compatibility dialog…nothing to do specifically with 3ds max.
if you’re looking for viewport performance in max then the Quadro line is your best option and offers “price scaling” according to budget… the response you got back from “Ayub” is a bit discombobulating because you can run max fluidly on a 4k display (across multiple displays with billions of visible polygons)… sounds like he’s referring to the “4k scaling UI” issue which you seem to have the most issue with. if 3ds max viewport display performance is the issue then it’s your hardware that is struggling to keep up - no doubt about it…
explains why it didn’t do anything.
viewport display issues wasn’t an issue until I got the new 4K monitor. Direct 3D works just fine, which causes me to think that it is a driver issue.
Also, I had a Quadro K5000 and it didn’t perform well at all. The forum here recommended the GTX 970 over the Quadro and I would agree. Up until know, I haven’t had an issue.
so in that case the common denominator in all your frustration seems to be the 4k monitor…
Actually, it would be MAX. All my other software looks and runs great. MAX is on record saying that it isn’t 4K compliant. I’m content running it at 200% and hopefully 2017 comes with good news on the 4K front.
ok, it sounds like you’re still stuck on the UI issue…
scaling is a workaround, but isn’t the best way to work. Basically, it’s like setting a 1920x1080 monitor to display at 800x600. Things get bigger, but look awful. Scaling to 200% just happened to fix my lag, too.
The native scaling is 150% and everything looks great, again, except for 3DS MAX. PhotoShop scales nicely and so does Office, and basically everything else. At 150%, MAX is still far too small and in my case, lags terribly. For me, 200% is the magic for MAX, but everything else gets too big and fuzzy. I’ll just work at 200% for MAX and what until MAX 2017 comes out. If MAX 2017 doesn’t scale properly, I am going to head up a coup.
Not to beat a dead horse, but it is also odd that you can change the scaling while in MAX and it’ll stop the lag without rebooting MAX.
Okay, I just stumbled across this. It lags when I go full screen, but if I minimize it a little, from full screen, it works.
I found another solution. If I rescale the MAX window, to something like 1920 x 1080, things work. I can keep my Windows settings alone and MAX looks and works like it should.
