more reflection
hi guys have small question
i have scene with sun with reflection on , and a plane with coronal light material with emit light on to give light and reflection but When I turn off the emit light the reflection of the plane also disappears.
well what I wanted was a plan with corona material light that only give reflection with the light turned off .. only reflection of landscape add
I think it interferes with sun with reflection on ..
anione have opinion to resolve this :confused:
thks
if I get you right, you have to turn off (Emit lights) in you CoronaLightMtl
thks … but if turn it off the light emitter (corona material light)on the plane ,only with reflection checked the reflection of the sun desappears …
i whant the reflection of the sun ..
i think there is some combination with priority that occuled … the plane with material light occulled the recflection of the sun wen the emitter is turned off … but wen is turned on the reflection of the sun appears
I think that in this case reflection from plane
overlaps of reflection from the Corona Sun. /If you use Corona Sun, as I undestand///
Try to use opacity slot in CoronaLightMtl///
thk you denisgo22 :smiley:
