Hi, i need to print with a plotter a big very big render, it’s posible to render with vray bigger than that appears in the output maximum resolution 2048x1536
thank’s
Re: MORE RESOLUTION THAN 2048x1536 posible?
The buttons in the Output section is only presets. You can type in manually any size you want.
ohh jajaj a little bit more and bit me
thank’s a lot thomthom, and excuse me for my inexperience
step by step ![]()
No worries. It’s what these forums are here for. ![]()
What is the highest possible resolution vray can render in sketchup??
Not sure.
But when you render really big files you should render to file in order to avoid running out of memory.
Should be a thread somewhere on how do set that up.
There is no practical memory limit, its just a matter of how much your computer(s) can handle. At our office, the guys in our studio have rendered 30,000+ x 30,000+ pixel images with VfMax, 64 bit systems, and DR. I’m not sure what’s the biggest vfSU could do, but you’re going to be limited by being a 32 app. Although it would depend on what you’re rendering, I would imagine that you could get to maybe 15-20,000 pixels square if you pushed it. You might have to be running it from a 64 bit system to get a little more memory. Also, you’d probably need to set aside 10-20gbs of harddrive space for the VRimage file. There’s also a good bit of technique setting up renderings that big…just changing the resolution and clicking render is simply not going to cut it.
GULP :o
In slightly more than an hour & half…its amazing what a little DR can do when its hooked up to a dozen 8 core render nodes
*droools*
I’m having an issue rendering. I input my render size in my vray options, but continue to only get the resolution of my screen. I need a render at about 3000 pixels but it simply won’t render to that size. any thoughts? thanks!
EXCUSE ME FOR MY IGNORANCE, BUT WHAT DOES RENDER TO FILE MEAN? AND HOW DO I USE IT? THANKS
If you don’t mind, please refrain from using caps. Its the equivalent to yelling, and there’s no need to yell.
When you render normally, the final image is actually contained in memory. It isn’t until you save that file that it gets written to your hard disc. When doing an intense rendering at high resolution, two things happen. First, more memory is needed for the rendering (whether its geometry or textures). Second, a high resolution image needs more memory to store itself. When you render to file, the image is not stored in memory, it is written directly to a file as each bucket finishes. This keeps the image out of memory, thus freeing it up to be used by other things. In general, this can prevent crashes that would have been due to running out of memory.
To use this it takes a few steps, but they aren’t hard. Just enable “Render to VRimge” in the Output rollout, set a path, and render as normal.* Next you will need to convert the vrimage file and to do that you will need the VRimg to EXR converter that can be downloaded from the link below. Now when you double click on the VRimage file, windows will say that it doesn’t know what to do with those files. Just choose the Vrimg2exr converter as the program to open the file with, and it should spit out an EXR in the same folder as the vrimage. Open that up in photoshop and proceed from there.
*Note, you won’t be able to zoom in and out, any your preview may have the edges of the bucket. Don’t worry, this is expected behavior as this is just a preview.
dalomar, thanks a lot for answer… and ecuse me for may caps, i was’t paying attention when i wrote that, now i reallizaed my mistake, i’m gonna try that tip, thanks again
Don’t worry to much about the caps…its just a pet peave of mine.
Hmmm…I can’t download the converter. It is saying that my passward is not allowed.
Any ideas ?
Try this one http://asgvistools.s3.amazonaws.com/vrimg2exr.zip
Damien, Exr. file cuts out the background. Is there an option to get the BG with the image?
I don’t think so. You can try removing the Alpha channel and see if that’s registered, but I think the VRImg file includes all the channels it can regardless of whether you’ve added the rendering or not.
Is it possible to download VRimg to EXR converter from anywhere else?
