d-3
1
Hi Guys!! my first post here and is to report a bug!!
If you setup the render with motion blur enable and save the file! when you open it the mb will be disable!
the same happens if you send a animation to render farm using backburner and pause the job and resume they will disable the MB!
Some one having the same problem or know a solution?
Thank you!!
This happened to me for some mysterious reason if I switched Corona builds a lot with a single .max file. Is this your case?
d-3
3
Hy Keymaster!
no i just switched one time to corona alpha r5 one time! and this happened! saved as a new file and keep happening.
I rendered the scene whith motion blur, but i need to be sure the backbunner don´t will stop or pause the job!
It´s a little pain!
Ondra_1
4
the motion blur checkboxes were merged into single new one one, hopefuly whatever problem was there is now gone
