Motion blur for changing geometry by v Attribute (forced)
Hi everybody,
Is there a way to force V-Ray to calculate Motion Blur by using the v attribute, instead of sampling the geometry?
I didn’t find an option to force it and as far as I can see, this is only done for particles automaticaly.
An example case would be when you merge in geometry in a simulation. Currently this produces incorrect results with defaults.
Or is there maybe another way?
Cheers,
Aleksej
Hello @Aleksej_Skrypnik , yes you can use v attribute for calculating velocity blur. Just need to switch “Geometry Velocity Blur” to “Velocity Blur” in geoObject > Render tab> Sampling sub-tab
Works perfectly. Thank you!
