Mountain Natural Scenery
Sketchup 2019 & Enscape 2.6.0 & Skatter 1.4.8
nice !
and whats new in skatter 1.4.8 ?
good job! :slight_smile: thanks for sharing.
Minor update for Skatter: v1.4.8
  • Added “Purge all Skatter data” in menu
  • Fixed Shift not affecting distribution on curves
  • Fixed curves with less than 3 segments being looped
Thank you for your appreciation. :slight_smile:
The scene looks very natural throughout. Thanks for sharing, it’s a great rendering! :slight_smile:
Thank you for your appreciation. I like creating nature.
It is real time and convenient to use skatter for cooperating Enscape. I can directly adjust natural form with whole scene. :slight_smile:
Great job!
I wonder if i can change the grass material in skatter library. I set the grass in skatter and i found the material is grass and the result isn’t so well. If the material of grass proxy is foliage will be wonderful.
You can make other grass models of SKP format into proxies which do not belong to Skatter — and just using the function of scattering with Skatter. By this, you can more directly control the textures of grass models.
Excellent
Thank you.
