Multimatte from Shader Material ID and Shading Groups
Is it possible to generate two different Multimattes from Shader Material IDs and Shading Groups? The Material ID of the Shading Group seems to overwrite the ones of the shaders.
This is not possible currently - the MultiMatte from the Shading Group will always overwrites the ones bellow.
You can use other render elements for additional masks like Material Select / Material ID / Object ID / Render ID and etc
