I’ve been doing some testing with the VDenoise tool and I’ve noticed that if I check the “exr multipart” option in the VRayOptionRE element, when I try to use the tool my only options are for the RGB color + Alpha elements. With multipart off, the full list of elements is visible. Is this a limitation? Are the multipart EXR’s actually read noticeably faster?
This is something we have to improve for our future releases.
Yep, there should be faster reading/updating for multi-channel exr’s when working in compositing.
@chadstevens I don’t know about Multipart, but if you add the VRayOptionRE element in CPU mode, you can use DWAA compression with the GPU when you switch back…at least helps with file size!
Yeah, I did notice that if you choose the option in CPU and then revert back to GPU it does seem to still affect the output, but I’ve not done much testing on it.
When I imported it into Fusion it did look like it came in as a multi-part exr which is promising.
