Multiple materials on object, but only one is rendering.
I put several materials on a single object but only the last one is rendering, as you can see on the image below. How can I apply multiple materials (blue labels) on the same object? Thanks.
There are many ways to do that, you can try a decal setup for example.
Decal not working. Thanks anyway.
If you can share the scene and the textures I’ll fix it for you
You need to tick the “add material” if you’re stacking alpha materials, then you map via the material’s uv space. But tbh, this is a messy workflow and a lot of effort to avoid uv mapping. There’s a GSG tutorial where the guy puts stickers on a skateboard, different engine but should work the same. It’s essentially the other way to do decals.
