Multiple (same) Enscape objects in 1 Revit-family
Hey everybody,
Is it possible to make a family containing multiple (same) Enscape objects?
I have a parametric family that makes a hedge wall (multiple nested hedges using arrays). When in the family-editor it works fine.
But when loaded into the project, it only shows one hedge.
I suspect it has to do with the EnscapeAssetId, but I can’t wrap my head around it.
Any help is appreciated
It’s definitely possible, but the nested family (the one you are arraying) needs to be “shared”, and that’s the family you want to have an EnscapeAssetId assigned to.
The main family should not have an EnscapeassetID (which, based on your description, is probably what’s happening here).
That was exactly it! Thanks!
