Multiscatter renders without materials (Vray toon Problem)
Hi there,
I am having a problem with the Multiscatter Plugin in conjuction with the Vray toon effect.
When Vray toon is turned off - all the Multiscatter Objects render fine.
As soon when the Vray Toon effect is enabled and set to “include objects” (several simple Boxes are included into the list) all Multiscatter Objects render without materials.
What could be causing the problem?
I am on Vray 5 Update2.30 and 3dsMax 2022.
Thanks in advance
I cannot reproduce the issue. Could you attach a simple scene, where the issue is present? Alternatively, send it via the contact form.
