My First Corona Renderer Image
Done initially in Vray and converted to Corona renderer.
472 is done entirely in Corona Render.
JIR
I like it. I’m not sure just about reflection on table.
“love birds” good!
I don’t like it. Something is completely wrong with edges of the branch (probably faked dof), flowers look like pieces of paper/plastic glued to the branch, post processing is too heavy, reflections on the table are not blurred which is inconsistent with dof.
Maru, you have a good eye.
Yes, its post processed DOF. I will render the image again with Corona DOF to be fair with the renderer.
Also I will try to use just Corona postprocess engine.
:wink:
Fully Corona Renderer…
Elapsed time 13hs 22min
472 passes
PT+HD
In my opinion - much better! What are those spots on the table?
¨fingerprints¨ which need to be done with a blend material.
like this test:
please watch in HD.
Juanon
Hi. Nice test. I think the fingerprints are too strong. You can try a refl gloss map and low values.
this one was 24hs rendering
