Need help making this texture.
Can someone please help me with this texture? I created the brushed map, but I can’t get the highlights correct. I can create multiple maps with the different exposures, but Im confused where to place everything. Should the brush be a bump map or diffuse? What IOR and anisotropy should I use? I am trying to get it where it looks very dark on angle.
You could use the Steel_Brushed_5cm or Aluminum_Brushed_5cm from the Preset Material Library as a starting point and adjust it further to your liking.
Please note the Anisotropy parameters and the Reflection map texture.
Let me know if you have any further questions.
Not easy.
most of the effect depends on the lighting, and on the bump map look, this is what I managed to do:
Unfortunately vray is not so good at keeping the bump detail at low resolutions …
