Net rendering
When we send the file for rendering (net rendering) using backburner.
where can i find the job sent for rendering.
I mean i would like to copy and back up the max and maps sent for rendering.
Hope i am able to explain well…
Thanking u all in advance.
Regards savio alvares
/user/“your user name”/appData/local/backburner/.. somewhere there
thanks for th help…but they do not saves the maps
Yep - backburner only sends the max scene unless you tell it to send the maps also.
joconnell thanks
How does one tell backburner to send the maps as well
When you submit the job go to options and check include maps, i always do that so each pc gets all the maps without fighting each other to read them from the server, the back hand of this is getting sometimes a huge file on my C drive, so from time to time a have to delete those files.
Have a nice render time
oligophant Sir
Thanks man got all i wanted…
thank u
is there somewhere on the DR slaves that a DR scene is sent? is it automatically deleted on render completion?
Example for Max 2013:
C:\Users\_user_name_\AppData\Local\Autodesk\3dsMax\2013 - 64bit\ENU\temp
Yes.
