Anyone know the possible cause for this? While rendering with V-Ray RT-CPU, if an image used for a texture map is located on a network share, then it renders as black in the rendered image. It is as if the image cannot be read so the default color black is used in the render. If the image is placed on the local hard drive, the image’s colors are used in the render. If the renderer is software based VRAY, the network based image’s colors are used in the final render.
Is there a log anywhere which v-ray would output errors or a way to increase the verbosity of output while rendering so it is easier to debug this issue? I currently see no errors in the script / console window while rendering in V-RAY RT CPU
OS: Windows 7 Pro
V-Ray For Maya Version: 2.40.02
Maya Version: 2014
Steps we have taken:
1) We disabled the firewall on the Windows machine. It was on originally so we turned it off and reboot the machine. This did not solve the issue.
2) The user can read and write data in to the directory where the image is located so it doesn’t appear to be permissions related, though there are advanced ACLs in place.
3) I used a different image format and the issue is the same.
Zdrasti Vlado (my family and I visit BG every few years). The below output was in the Maya console window. I see no Windows console window (cmd.exe) appear when V-ray RT is run. Perhaps our machines are set to supress those from opening up within the OS or Maya? I’ll have to ask our sys admins about that.
However, here is the output from the maya console window. Is this the information you were seeking? I do not see any errors which seem to explain why network based image maps are not being accessed properly.
Everything seems normal in the log file.
Are you using UNC paths or mapped drives for the network images?
Furthermore is the issue only with V-Ray RT? What happens when rendering with V-Ray Adv?
What about V-Ray RT in GPU mode?
Is the issue scene dependent, does it occur on a fresh new scene with a few simple primitives?
Would it be possible also to test version 3.x? If you don’t have a license for it try with the demo version.
We are using mapped drives. I just tried UNC path and the image still doesn’t seem to contribute its colors in the render.
The issue is only with V-Ray RT CPU. V-Ray GPU doesn’t work on our systems due to incorrect cuda setup which I am waiting for systems admin to investigate because I lack Admin access. V-Ray Adv has no issue using the network based image map.
The issue happens on a fresh scene that I made myself too. I used simple primitives.
In a few weeks I can test out V-Ray 3.x after our project delivers.
I’ve visited Plovdiv (often), Sozopol, Varna, Devin, Rila Monastery area, Melnik area, Bansko, Veliko Tarnovo, Dyavolsko Garlo, Sophia (before I knew anything about V-ray i remember walking somewhere near the center of Sophia and I saw a sign that said “chaos group”..not near the current office location though)…Last year we drove from Plovdiv to the Greek island of Thasos and we stayed in a few towns along the route.
