Network rendering problem with Vray RC3.
Hello
I have a problem with the network rendering and vray :
I use Vray 1.50 RC3.
I have a scene that calculate on local but not on network rendering ( backburner ), it’s verrryy slow… in fact it cannot be rendering on network.
I have tested to calculate the same frame on the same machine, on local and on rendering network. Result : 6 minutes on local and infinit time on network rendering.
In the rendering window it shows that : “prepass 1” --> “presampling dislpacement” ---> “unloading geometry” ---> prepass 1… and again and again.
Why ? it doesn’t make that on local !
I have tested to increase the dynamic memory limit and some other parameter but it doesn’t work.
I use 2D displacement, GI, and translucency.
I have tested with the vray 1.49 and there is no problem with this version !
Edit : I have tested with vray 1.50.06 --> working
         I have tested with Vray 1.50 RC2 --> NOT working
Best regards
Max
how much ram is it using when its trying to render?
We have 4 giga of ram
i have added “/3bg” in the boot.ini to have more memory
the calcul takes about 2.5 giga
vray 1.50.06 doesnt exist! well there is a warez version around but no official build.
I know. but it’s impossible to get older version of Vray RC3 in the website. only the 1.47
