Ok- I read all the articles in this fourm on Vray DR and I have several questions I couldn’t find answers to. I am familiar with setting up backburner so I’m not completely clueless when it comes to network rendering. In this particular scenario, I have NOT set up backburner. is this necessary? Here’s what I’ve done so far. I was hoping someone would be kind enough to tell me if my settings look messed up.
1) Installed all plugins across machines. Setup is basically identical.
2) Set up a ‘transfer’ folder that’s shared out across the local network- i.e. “\compname\transfer”
3) Installed Spawners on machines. Set them as services. Directories set to folowing:
a. Spawner Temp Directory: \\compname\transfer
b. App Exe.: c:\3dsmax5\3dsmax.exe
c. VraySpawner Dir (normally the same as Max/Viz Folder): c:\3dsmax5
4) Ok so this being set up identical on all machines- I’m not too positive about the spawner temp directory (3a). Should this be local?
5) Then when I launch Max on one machine- do I need it to be open on the others? This is not the case with backburner. I take it that you don’t need it open cause that’s why it is a service…
6) I selected the scene on the main machine. ALL my materials/scene files are located in one folder on the desktop for this particular project. I realize it’s a pretty bad habit. Does this need to be moved to the ‘transfer’ folder? Or is it smart enough to ‘pull’ from this directory. It would be a pain to have to move a directory over to a shared location every single time. I’m also wondering how DR is going to handle the materials as well as the HDRI map.
7) Set Max to Vray as the current renderer: System\Distributed Rendering. Click on settings. Now I add all servers or is there only one- the main machine needed? My search doesn’t pull up anything. So what I’ve done is entered IPs through add server. They pull up and show themselves as “disabled.” I enable them. I clicked on them and hit “resolve.” The names now pull up. The comp icons are green.
8) “Auto-management” is checked on to ‘promote new servers.’ Leave bucket label is NOT checked (I have no clue what either one of these does but I’d like to.)
9) I don’t know what to do with the following in the settings as I had thought I set these up through the wizard:
a) Projects Directory: c:\DOCUME~1\LOCALS\~1\Temp (default) - browse button can be activated. does this need to be set up to the same as step 3a?
b) Network directory: (blank)- browse unselectable
c) MAX directory: (blank)- browse unselectable.
I activate the DR checkbox. So then I hit ‘render’- it pulls up a preview window and it just hangs blank. I see nothing happening. I run over to the other computer and nothing is happening on the screen (I mention that Max hasn’t been started on this comp MAX hasn’t been started.)
Apologies for asking so many questions but I think I am being very thourough as to my steps. I haven’t seen anything too detailed about a proper setup in this forum (I’ve read through all of them.) It’s usually abbreviated or people run into issues with their settings. It’s all a little bit confusing path-wise. Are there any other external settings in the main render scene dialog that I should switch on?
-jujubee :?
