Hi all, I’ve recently built a new 12-core Xeon v3 system and I had a few questions:
- Do I need to configure Corona / Max in any way to obtain optimal rendering speed with this many cores or is everything good to go?
- I’ve noticed IR renders are a lot more noisy /don’t clean up as well than non-IR renders for the same amount of time. Is this something to do with how IR uses the CPU cores or just the way the IR algorithm works?
- Will there be any issues using my old 3930k 6-core system as a render slave considering it’s a different type of CPU and uses DDR3 ram? (new build uses DDR4)
The old system is out of commission until I get my new graphics cards, so I haven’t been able to test DR, but I thought I’d ask ahead to time / to save myself any headaches.
Thanks!
