New build, looking for cooling advice for 3970x and PSU
HI,
I need to get parts ordered asap and need a bit of advice on cooling a 3970x for my new workstation, no real preference over AIO or air, just want someting that will work well and will fit when all ram modules are used.
Have a corsair H100i in my old build - couldn’t fault it, but not sure if the new models are as good as the older ones, also I hear Noctua are excellent for air cooling,
is there anything i should be aware of,
also any advice on the PSU, (graphic card for now will be my current 1080ti)
thanks
T
Just go with a Noctua NH-U14S TR4-SP3 an second fan. I have it and it is reliable and quiet.
Get a Corsair AX1600i if you plan for two rtx 3090 or the Corsair Professional Series HX1200i for one rtx 3090.
sounds good
cheers
Have the same setup as bildform suggested, Corsair 1500 W, 3970X + Noctua NH-u 14S TR4-SP3 with second fan and a RTX 3090. It`s a quite setup and cpu temps don`t go over 70° max. but with precision boost disabled. Once i activate it, temps go easily to 90° and above, so therefore you would propably need a water cooling system.
If you are fine with the default 3700 Mhz, thats the setup to go for.
Has anyone experience of Raid 1 for storage disks with AMD, should i use their raidexpert2 or just do mirroring in win10 disk managment?
last build was on an intel chipset and i used Intel RST for the arrays, worked great,
