Hi all,
Some test done with the hair shader in Corona, some hair render and some fur test render
the shader is still in early stage, more to come ot it
But it look’s already amazing , with glint working and other stuff it will look even better ![]()
Corona quality ! This new shader seems to keep one’s promise. Awesome !
And nice model !
Impressive!
I like how he “Bigguns” the tests, honestly it looks nice.
Is it only shader? Or some hair/fur method aswell?
Promising!! Good job.
I must admit, that’s way better than I expected :- )
This looks mega. Shame we can’t use it with max’s H&F though :[
So currently Max’ own H&F doesn’t work at all? Not even with the material controls within the modifier?
Great results, btw! I was sure the first image row was the reference until I saw that only the small pic is a photo ![]()
is it with ornatrix?
it’s with hairfarm
Yes these look amazing. As a C4D user we are out of the loop on the latest features. Can this be used to generate the fur - or grass more specifically? or is it just the shader that needs to be applied to a hair solution created externally with another plugin?
It won’t generate fur nor grass - it’s just a material, which you can apply to your already generated hair or mesh.
Ah right, thanks. Do you know if there are any plans for that sort of feature within Corona?
With hair Farm, does the base objet render with version 1.7 hotfix?
yes
