New Laptop
Hello everybody,
I assume this has been discussed a million times, but I‘m currently looking for a new laptop (15‘), to work with both :revit: and :sketchup: . If you could go ahead and pick any laptop you want, what would it be?
Thanks in advance
Any laptop with at least an RTX 3060, 3060 Ti, 3070, 3080, or 3080 Ti, up to the 3090 based entirely on your budget will be great for Enscape. If you buy a prebuilt machine, the CPU / RAM and so forth should be sufficient anyway as the GPU is the most vital part for Enscape generally - If you also wish to make use of VR in the future, we recommend going for at least a 3070, ideally one above even.
Hope that helps! If you wish to share any specific models here with me too please feel free to do so of course.
Hi Demian,
thanks for your reply. I´ve narrowed down my search and i´m currently thinking about a Razer Blade 15 (Base) and a MSI Creator 15. Both with an RTX 3070. No need for VR
Sounds great! If you aren’t using VR anytime soon then the 3070 will be greatly suited for normal day-to-day use of Enscape.
