I’m wondering if there is some setting I’m missing. When I use Next IPR it brings my computer to its knees. And I have a pretty powerful machine (see my signature). I’m not at all experiencing the joy of IPR previewing that was advertised for Next. Don’t get me wrong, I love Vray. But my machine becomes completely unusable if I’m running a 600x600 IPR frame of even the simplest of scenes.
I’ve tried changing the ‘Affinity’ of Max in Task Manager but it always flips back to using all processors no matter how many I turn off. I’m not able to derive any benefit from IPR as it’s just crippling.
Any suggestions for settings I can check for to try to get IPR to the point that it’s helpful?
Do you mean you can’t multi-task while the image is processing? Hmmm… that stopped happening to me a while back. For me, I had to turn off Volume Shadow Copy or my machine would crawl every 30 seconds. That’s not a V-Ray thing and I haven’t heard of anyone else having to do this, but watch your Task Manager and see if it is popping up every 30 seconds.
I turned Volume Shadow Copy off once before to diagnose another unrelated issue and it completely nuked my backup software that images my machine once a day. However, I’ll disable it now for a few minutes and test to see if that’s it. I’ll report back in case it helps others.
I hope I can find some other bottleneck should disabling VSC solve it. I can’t disable that.
Mine arrives Monday. I only have the power connectors for one large card, so two large cards wasn’t an easy option. I might be building a new machine later this year, so I might get a second Titan RTX; we’ll see.
If it’s common knowledge that VSS impacts V-Ray’s IPR functionality I hope Chaos Group can find a way around that. Turning off critical Operating System functionality to run a program is a terrible solution. Maybe someone else will have found a better configuration I can try.
Last comment about the Titan before we are asked to move it to it’s own proper thread, I’ve been using a Quadro K5200 for about 3-years and am looking for my next GPU. I’m looking at the Titan cards. Was curious why you chose it specifically.
It is supposed to be the best card available. It’s pricey, but it should pay for itself within a month or two. With two of them, and VRAM, there won’t be much I can’t through at it. There is a 48GB card and it’s twice the cost, so the Titan is scalable. The Quadro’s are supposed to be goood for viewport performance, but the GForce is supposed to be better for rendering.
Next IPR is still crippling my machine. When I use it, I can barely get the mouse to move up to ‘stop’ the render. I go to ‘Task Manager’ and turn off 5 or 6 processor threads and then just get re-enabled. There used to be a setting in the ‘Render Setup’ that set ‘Low’ CPU or something but that’s gone.
I love IPR but it brings my machine to its knees. I can’t even check email while I wait for rendering to progress.
This same thing occurred with my Quadro K5200 card and my new RTX 2080 Ti. It’s not the video adapter’s fault, it’s V-Ray’s aggressiveness. We need some way to limit it or else IPR is not a feature that is beneficial as it makes the production workflow worse instead of better.
